Phone doesn't turn on
Deadboot phone it doesn't turn on, it automatically turned off it's power and it does not indicate charging or response.
Is dit een goede vraag?
@jamesmarsh12177 first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger.
Commonly a No Power situation is related to either the charging board, a shorted battery or a torn flex that comes from the daughter board to the main circuit board. Check/replace those. Then check the voltage on your battery connector with the phone plugged in and without.
To replace the battery, use this guide Poco X3 Pro Battery Replacement For the rest use this video Let us know what you find out.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 292
Hi @jamesmarsh12177
Does the phone indicate that the battery is charging when a known working, compatible charger/charger cable is connected to the phone?
Has the phone been dropped or gotten wet at all?
door jayeff
