Ga door naar hoofdinhoud
Uitgebracht op 7 december 2021 195 g, 8,8 mm dikte Android 11, MIUI 12.5 64 GB/128 GB opslagruimte, geen kaartslot
How to change lcd screen
Is dit een goede vraag?
Score 3
2 opmerkingen
How to lcd displays screen chenge
door
@udaysingh60305 follow the given answers.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@jamescorpu47556 since iFixit does not yet have a guide for this, use something like this video Replacement LCD's are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Score 3
To change the LCD screen of a Redmi Note 11T 5G:
  1. Power off the phone and remove the SIM tray.
  2. Heat and gently remove the back cover.
  3. Unscrew and lift the mid-frame.
  4. Disconnect the battery and display connectors.
  5. Heat the front screen and pry it off.
  6. Replace with the new screen, reconnect all parts.
  7. Reassemble and power on to test.
Score 1
Voeg je antwoord toe
James Corpuz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 62
Altijd: 1,290
