Ga door naar hoofdinhoud
De V2-controller is verkrijgbaar in verschillende generaties. Je bekijkt nu generatie 4.
extremeRate modded PS4 controller, Square unreliable
Hi all, I grew tired of replacing the rubber under the dpad on my PS4 controller and decided to try modify the controller to use the extremeRate clicky button kit. Which worked well, until the other night when square stopped working reliably.
I know the problem is the contacts between the extreme rate and the top side of the main board. Tightening the silver 00 6mm Phillips screw that holds the contacts together fixes it, but after an hour of street fighter it was back to missing square inputs.
What i think has happen is the threaded hole on the underside of the controller face panel has been damaged and is becoming loose. I might be able to harvest the face panel / screw from an old controller, although I'm not sure this a viable solution.
An alternative solution might be to get something to push against the bottom side of the main board... Or even the battery? This in theory would maintain the contacts. But I haven't a clue how I'd do this.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Broken or loose cables, bent or worn cable connectors, or loose or damaged internal wiring are the causes of the Sony MDR-7510 right ear headphones' lagging and sporadic sound. Check the cable plug and socket, test with a different cable, examine the solder joints and internal wiring, and either replace the cable or fix the connection to resolve the problem. The simplest solution is typically to replace the cable if it is defective or the connector is broken. Repair or expert service may be required if the internal wiring is damaged. If you need help, the author can walk you through opening and inspecting the headphones or help you locate replacement cables.
Was dit antwoord nuttig?
1 Opmerking:
@i_am_the_cosmos AI answers are so generic. They do not help anyone. Try to be more specific.
door
Voeg je antwoord toe
Gordon Hall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 329
