Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Tab A9+ werd uitgebracht in oktober 2023 en beschikt over een 1920 x 1200 pixel lcd-scherm, aangedreven door een Qualcomm Snapdragon 695-processor, met maximaal 8 GB RAM, 256 GB interne opslag (uitbreidbaar via microSD) en een batterij van 7040 mAh.
LCD screen Dim Backlight issue
Hi everyone, I'm a computer technician. A customer brought me a galaxy tablet (Galaxy tab A9 plus (SM-X210) complaining regarding very dark screen whilst the tablet still on but you can only see things on the screen under the sunlight or under UV light, which is still very hard to see! However I have replaced a brand new screen and resetting it to factory settings and updated but still the same. Now I know the issue is not the actual screen. I'm assuming the backlight for the LCD screen it is on the motherboard but I do not have the motherboard diagram for this model so I can desolder or replace. I'm not too sure where the component for the backlight is located or what is causing this. thank you in advance. Any help greatly appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @adam49009
Here's some information that may help:
  • Website that has the board layout diagrams (and also the schematics). I'm not on FB or have an account with the site so I don't know how much it would cost.
  • Samsung SM X210 Service Guide so that you can check if everything OK if you get it working. Unfortunately there are no board layout diagrams, troubleshooting flowcharts or schematics in the guide.
  • Samsung Members app used for testing the various functions in the tablet as described in the service guide.
Also just verifying the the LCD panel that you installed is Samsung part # GH81-24554A and not something else just in case it is slightly different as to the wiring connections being used?
LCD display and touchscreen assembly for Samsung Galaxy Tab A9+. Afbeelding
Product
GH81-24554A - Samsung Galaxy Tab A9 Plus Display Touchscreen
$57.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Adam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 59
Altijd: 984
