Ga door naar hoofdinhoud
Reparatie- en demontagehandleidingen voor honderden optische schijven.
Repairing optical drives instead of just replacing
Does anyone have advice for repairing optical drives. I have one that sometimes reads a disk but if I try to burn a disk I get errors. I work in an e-cycle plant and we get quite a bit of them and repairing seems like a better option than just replacing.
Is dit een goede vraag?
1 Opmerking
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@jerrywitherite most common failure for something that you describe would be a weak laser. Sometimes increasing the voltage to the laser slightly by adjusting the trimpots (never do that without a meter or you could burn it out). Ultimately replacing the laser would be the only real fix.
Was dit antwoord nuttig?
they are so cheep. throw it away and try another.
1 Opmerking:
@altonbell40070 the iFixit community frowns upon throwing stuff out just because "they are so cheep". Check on here https://www.ifixit.com/Right-to-Repair to see what this is all about.
door
Charge problem
Voeg je antwoord toe
Jerry Witherite zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 415
