Ga door naar hoofdinhoud
De draadloze Xbox One-controller werd geïntroduceerd in 2016 bij de lancering van de Xbox One S en voegt Bluetooth-ondersteuning toe voor Windows 10/11. Deze controller lost veel van de ontwerpfouten op die in de Model 1537/1697-controllers werden gevonden en is veel betrouwbaarder. Deze controller is vervangen door de verbeterde Model 1914-controller.
How can I make it turn on?
It seems a battery exploded inside the port and calcified the connector and it's surroundings. I already cleaned it as best I could with a bit of alcohol but it doesn't seem to register that it has batteries, even though I put in fresh ones. That being said, when I connected it to my laptop through cable it seemed to receive power and turn on.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi Alex!
Oh my... The only thing you can do is to clean it with isopropryl alcohol. The whole motherboard, but this is what you already did.
So, the next step is to replace the battery pins for new ones! Soldering is required, but it's not that difficult.
If that didn't worked, then there is something (or more things..) damaged on the motherboard. If this is the case, it's probably not worth to repair it. Sorry.
Hopefully replacing the battery pins will do it!
Was dit antwoord nuttig?
Voeg je antwoord toe
Alex Gonzalez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 132
