Ga door naar hoofdinhoud
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Vragen Bekijk alle
replacing battery, bottom logic board overheats
I have a ipod touch 4 that has a dead battery.
I tried to replace the battery and made sure that the contacts are not bridging... however once I solder the +, ground and negative contacts the board starts to get really hot! i immediately de-solder the battery.
Is the battery bad?
What would cause the board to heat up? thank you.
Is dit een goede vraag?
Score -1
1 Opmerking
Also I am able to power the device on via usb cable and it works fine.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
tony tony, definitely check on your soldering. It does sound like you are short circuiting something. If your work is done properly , I would suspect you have a battery with a short circuit. Replace it and see if it makes a difference.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I am getting the battery exchanged. I cleaned off the soldering and waiting for the replacement in the meantime. Thank you again.
door
But I still can't find the processor speed~
3 opmerkingen:
Alex, did you post this to the wrong question:-) ?
door
These are 1GHZ A4 processor underclokced to 800MHZ last time i bothered to check
door
Does this in any way pertain to the above question? I seem to be missing something....It looks to me like Alex comment was meant for this http://www.ifixit.com/Answers/Ask/iPhone...
door
Voeg je antwoord toe
tony tony zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 663
