Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Asko Appliances AB was een Zweeds bedrijf dat huishoudelijke apparaten produceerde, zoals koelkasten, vaatwassers en wasmachines. Het was gevestigd in Jung in de gemeente Vara in Västergötland. Asko Appliances is nu eigendom van Gorenje Group, die deel uitmaakt van de Chinese fabrikant van grote huishoudelijke apparaten Hisense
What is the Error code E10
what is the Error code E10 for Asko Dishwasher and how to fix ir.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
What is the model number of your dishwasher? Asko makes quite a few different ones, and getting you the correct answer depends on which one you have.
Knowing the model number is essential in this case, as a general search for Asko dishwasher error codes shows that most Asko DW's use error codes that start with "F" rather than "E", so we'll need to confirm.
The only result I came up with that seems to be close is a video on YouTube describing an Asko DW with an E10 error code. They claim it's a water level sensor error, which could be the sensor itself, the wiring going to it, or an issue with the control board. The only real helpful information they have to offer is to tell you to turn off the dishwasher, unplug it for a full minute, then plug it back in and see of that helps. If not, they say you should then call a technician. :-/
E10 Error on Asko Washing Machine - How to fix - YouTube
Update (04/10/25)
A search for Asko documentation on your dishwasher turned up a user manual, which includes a troubleshooting section listing error codes.
User manual Asko DWCBI241.S.AU (English - 46 pages)
Here's the information relevant to your problem.
The Care and cleaning section has this information on clearing the drainage pump.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for your prompt reply. Sorry, the error code would be F10 and model number is DWCB1241.S.AU
door Deel
Voeg je antwoord toe
Rashedul Alam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 462
