Ga door naar hoofdinhoud
{A1706 / EMC 3071}—Uitgebracht in juni 2017, deze 13" MacBook Pro is voorzien van Kaby Lake-processors tot 3,5 GHz Core i7 met Turbo Boost tot 4,0 GHz.
How to fix/replace component underneath the key piece?
My E key has been missing for a while, but the component underneath still worked when pressed. Now, it’s no longer working. Can I replace just that break, or do I need to order a whole keyboard? TIA
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
You should be able to replace the scissor mechanism as well as the rubber bumper. Here is a source for the needed parts TheBookYard - MacBook Pro keyboard parts click on the image to dig into the different caps and other parts.
Was dit antwoord nuttig?
@valeriasan26150 here is the A1706 Keycap Replacement procedure. Take a look at page 2 for the explosion drawing on your keys. Although keycaps can be replaced, the butterfly and switch housing cannot. A damaged switch housing or butterfly requires replacement of the entire top case.
1 Opmerking:
Sorry OT I’ve replaced them using this part Keycap Mount and Dome - Alphanumeric
door
Voeg je antwoord toe
V santi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 218
