Ga door naar hoofdinhoud
De C/K, officieel de Chevrolet C/K genoemd, is een serie vrachtwagens geproduceerd door General Motors en op de markt gebracht onder de merknamen Chevrolet en GMC. De C/K-lijn omvat pick-ups, middelzware vrachtwagens en zware vrachtwagens.
Exhaust backfire and Missfire
98 c1500 5.0L. I have a backfire it sounds like my exhaust is kicking into my floorpan. It only happens after the vehicle hits operating temperature. I have replaced the Spider Fuel injectors, wires, plugs, and distributor.
It just started throwing a P1345 code. But has had a misfire code for a random misfire
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@dakotasanders based on the symptoms you are describing as well as the P1345 code, this sounds like either a bad camshaft sensor or a bad timing settings. Since P1345 relates to the camshaft and crankshaft sensors alignment to each other, you can't count out the crankshaft sensor either. I'd replace the sensors, reset the PCM. This from a workshop manual
DTC P1345 - CRANKSHAFT/CAMSHAFT POSITION SENSOR CORRELATION
Circuit Description
DTC determines if distributor is installed incorrectly, or if a mechanical malfunction is present in engine.
DTC will set when engine is running, cam sensor reference pulse is not detected at correct relative position with crank pulse.
Diagnostic Procedures
1. Perform POWERTRAIN ON-BOARD DIAGNOSTIC (OBD) SYSTEM CHECK , then go to next step.
2. Install scan tool. Start engine. Using scan tool, monitor engine RPM. If engine RPM fluctuates up to twice the expected RPM, go to next step. If engine RPM does not fluctuate up to twice the expected RPM, go to step 4).
3. Replace crankshaft position sensor. After replacing sensor, go to step 8).
4. Check for proper installation of distributor. If a problem is found, go to step 7). If no problem is found, go to next step.
5. Check for proper installation of distributor. If a problem is found, go to next step. If no problem is found, go to step 8).
6. Repair as necessary. After repairs, go to next step.
7. Replace distributor. After replacing distributor, go to next step.
8. Using scan tool, select DTC, CLEAR INFO. Start and warm engine to normal operating temperature.
Select DTC, SPECIFIC, then enter this DTC. Operate vehicle within the conditions for setting this DTC.
If scan tool indicates that this test ran and passed, go to next step. If scan tool does not indicate that this test ran and passed, repeat step 2).
9. Using scan tool, select CAPTURE INFO, REVIEW INFO. If any undiagnosed DTCs are displayed, go to applicable DTC test.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dakota Sanders zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 140
