Ga door naar hoofdinhoud
De Acer Nitro 5 AN515-58 is de uitgave van 2022 in de Acer Nitro 5-serie. Deze handleiding zou compatibel moeten zijn met alle varianten van de Acer Nitro 5 AN515-58.
How do I replace my CPU and GPU fans
Yeah so I need to replace my fans on my Nitro AN515-58, I’ve tried cleaning the fans, didn’t work, fairly new to this stuff so I might need detailed instructions or a video.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @cluelessperson
Here's a video that may help.
To find replacement fans, check for any model number or part number information that may be on the fan itself and if there is, search online using that information to find the correct fans for the laptop.
If there is no information on the fans themselselves search online for Acer Nitro 5 AN515-58 fans, but ensure that they specify the complete model number and not just the model series.
Note: Ensure that you disconnect (unplug) the battery cable from the motherboard as soon as you can access it after opening the laptop to minimize the possibility of causing any electrical problems on the board during the repair. Reconnect it last thing you do before closing the laptop after the repair is complete,
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Cluelessperson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 50
Altijd: 821
