Ga door naar hoofdinhoud
De C/K, officieel de Chevrolet C/K genoemd, is een serie vrachtwagens geproduceerd door General Motors en op de markt gebracht onder de merknamen Chevrolet en GMC. De C/K-lijn omvat pick-ups, middelzware vrachtwagens en zware vrachtwagens.
Water pump replacement time
Water pump replacement timeframe
Is dit een goede vraag?
1 Opmerking
@kodyarnold what is the year, the model and what engine size?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
When it starts leaking or making noise. I'm not aware of any kind of recommended replacement interval like there is for timing belts or oil changes.
Update (03/13/25)
No problem, Kody. I don't know the details of your rig yet, but on my son's 1985 GMC High Sierra (K2500) with a 350 ci engine, it's a pretty straight-forward job. Once you have the belts out of the way it shouldn't take more than a half hour or so; add another half hour for the belt R&R and an hour should be enough time.
Was dit antwoord nuttig?
3 opmerkingen:
I meant the time frame to actually fix it not when to replace it my bad
door
Yeah sounds about right it’s a 98 but it’s also a 350 so I assume not much change besides maybe the water pump part itself but I believe they are in the same common area
door
@kodyarnold Yep, not that much difference in that area. If you've ever had to replace a water pump on these new models that use the timing belt to drive the pump, now there's a pain in the behind. I'd much rather have one out there sitting proudly on the front of the engine where you can actually get to it. On my son's truck I can climb on in the engine compartment to work on it.
door
Voeg je antwoord toe
Kody Arnold zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 265
