Ga door naar hoofdinhoud
How to oper for accu replacement?
how to open the device? is there a central screw in the key board?
Update (03/10/25)
Type: HP Pavilion x360 Convertible, Model: 13-u167nz
Apparently there is a hidden central 9th screw in the center of the keyboard, which prevents me from liftig it to replace the battery. Or is it a clamp ore something similar?
Is dit een goede vraag?
2 opmerkingen
Hi @wolfgangwe66244
What is the full model number and product number of the laptop, as shown on the product information label on the bottom of the laptop?
door
excellent help !!!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @wolfgangwe66244
There are 10 screws on the base enclosure that hold the keyboard/top cover in place.
Here's the maintenance and service guide, that is applicable to your model also.
Go to p.42 (50 of 94 pdf) in the manual to view the procedure to remove the battery.
Once you have the laptop open, just to ensure that you're getting the correct replacement battery and that it hasn't got the same part number (844203-850) for the battery as shown in the manual, locate the HP part number printed on the battery and then search online for the part number only, to find suppliers that suit you best.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
perfect :-)!!!
door
Voeg je antwoord toe
Wolfgang Weber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 301
