Ga door naar hoofdinhoud
Uitgebracht in juni 2014, te identificeren aan het modelnummer B051.
Help Diagnosing - Right Side not Working
Hi all,
I was hoping to get a second opinion on a pair of Beats Solo 2's I just picked up from the thrift. I'm a bit of a noob when it comes to headphone repair so I wanted to make sure I'm on the right path before spending any money on them.
I tested them on 2 different audio sources with 2 different cables, so the problem is definitely in the headphones themselves.
I've used a multi meter continuity function to test the two wires (R and RG) from the left side to the right, and both sides have continuity. I've also tested the continuity between the jack's right side input and the jack's ground and the continuity is good to the pads on the right side.
When I measured the resistance between the positive and negative pads on both sides of the headphones, the left (good) side measured in at 30 ohms, while the right (bad) side measured in at 650 ohms.
This leads me to believe the driver itself is bad, correct? Hoping to get some corroboration before I pull the trigger on a new driver. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
If the right side of your Beats Solo 2 headphones is not working, here are some troubleshooting steps to diagnose and possibly fix the issue:
1. Check the Audio Source & Balance Settings
Try another device: Plug the headphones into a different phone, laptop, or tablet to rule out a device-specific issue.
Balance settings: On Windows, go to Sound settings > Device properties > Balance and ensure the right channel isn't muted. On Mac, go to System Preferences > Sound > Output and check the balance.
2. Inspect the Cable (For Wired Version)
If you have the wired version, try another AUX cable (if detachable) to check if the issue is with the cable.
Inspect the cable jack and headphone port for dust, debris, or bent connectors.
3. Check for Bluetooth Issues (For Wireless Version)
If using Bluetooth, disconnect and reconnect the headphones.
Reset your Beats:
Hold the power button + volume down button for 10 seconds until the LED blinks.
4. Test Mono Mode (For Wireless Version)
Try enabling Mono Audio Mode on your phone (in Accessibility settings) to check if the right side produces sound.
5. Physical Inspection
Check if the right earcup speaker is loose or damaged.
Wiggle the hinge area—sometimes, a broken internal wire can cause this issue.
6. Try a Factory Reset (Wireless Only)
Hold the power button for 10 seconds until the LED flashes.
7. Internal Wiring Issue (For DIY Repairs)
If you're comfortable with disassembly, open the right earcup and check for loose or broken wires. Many Solo 2 models have fragile internal wiring.
Re-solder or reconnect any detached wires if needed.
8. Contact Apple/Beats Support
If under warranty, Apple may offer repairs or replacements.
Let m
e know what you've tried, and I can guide you further!
Was dit antwoord nuttig?
1 Opmerking:
@vishalhal while AI can be a useful tool for some things, us moderators here at iFixit do not feel it can be relied on as a sole authority for answers to repair questions. So while we won't remove your answers or ban your account for using AI, we would strongly request that you indicate that your answer is generated using AI so our users can judge the accuracy of the answer for themselves based on that knowledge.
Should you continue to offer AI answers without indicating them as such, iFixit employees may contact you with stronger warnings, possibly leading up to being banned from the site.
door
its an apple fact when you use their headphones with another device not apple.. they set the software inside headphones to stop working.
Voeg je antwoord toe
Demitrius zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 242
Altijd: 4,745
