Ga door naar hoofdinhoud
This Apple Cinema Display is characterized by the M8149 model number and was first released in July 2000
7 Vragen Bekijk alle
Vraag afgerond
replacement of scratched display protector
hi i'm looking to find out if i can get my scratched 23 HD cinema display, is the front panel removable? i tried calling my local apple service center to no avail, any help much apreciated :)
Is dit een goede vraag?
5 opmerkingen
Have you had much experience in taking things apart Jones? I would look through some of the guides that closely resemble your device and look at the layout on the outside and work from there in deciding how easy it would be to take apart to reach your screen. I'm trying to find a source to help you better at the moment :)
door
Apple Cinema Display HD (23-Inch) Specs
Identifiers: Cinema HD Display - M8537ZM/A - N/A
door
jones, just in case Gary can't find his guide, you can download the SM for a limited time from here Good Luck.
door
OT - I'm working on a wiki for the first Apple Cinema Display 22". Can you give me a link for the service source FOR IT? THANKS
door
mayer- Here you go Sir...
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sorry, I got so involved with correction of the wikis on the Cinema Displays I forgot to give you an answer. Here's how to do it: Apple Cinema Display M8149 LCD Screen Replacement
Was dit antwoord nuttig?
Score 3
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,425
