Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in Japan op 12 december 2004, in Noord-Amerika op 24 maart 2005 en in Europa op 1 september 2005.
PSP 1001 Right Trigger Unresponsive
Basically I haven't used the PSP in some time and after starting it again I noticed the right trigger is toast, doesn't respond to any clicks.
Anyone know what might fix that?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi Alex!
Someone did made a video about how to fix this!
Link: https://youtu.be/edSyysTaAGg?si=0MtDtEgR...
Part:
https://a.aliexpress.com/_EzjnG9i
I repaired many of them and it’s easy! You need to replace the whole flex cable and after this it should be fine.
You need the PSP1000 one. If you have any questions, please let us know!
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
Interesting! I'm a little indimitated at how many parts seem to be in the console but I'll see if I can give that a shot. I'm guessing it's more or less you unscrew the whole thing and simply replace that part you order for it?
Thanks!
door Deel
Hi Alex! Yes that is correct. You need to take the front cover off, then the home button, volume buttons, etc bar, be careful to take it out the connector, all of them are very fragile. And then remove the LCD (it's still connected to the motherboard, so again, be careful). Then take the right board out. Follow this guide: PSP 1000 moederbord vervangen (till step 16) and then put the new part in and reassemble it again. Good luck and be careful!
door Deel
Gonna aim to try that. Thanks Again!
door Deel
My pleasure!! Good luck with the repair!
door Deel
I replaced the cable on my own psp 1000. All the buttons work with the new cable except for the right trigger (the one I was trying to fix). Any ideas an what to do?
door Deel
3 commentaren meer tonen
Voeg je antwoord toe
Alex Reichmann zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 98
Altijd: 1,658
