Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en hulp bij probleemoplossing voor de haakse slijper van Makita met een slijpschijf met een diameter van 7 inch en het modelnummer GA7011C. Deze slijper is gemaakt in 2017.
Switch push button repair
I have opened the push button and now don't know how to repair it
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi John,
I have to agree with bill that on parts like electrical switches, it's rare that we can actually fix them when they're broken; the normal repair is to just replace them. The device page does have a parts diagram that shows your switch and gives a part number for it too. Clicking on the picture of the switch brings up the information as follows:
An online search for "Makita 651922-3" brings up quite a few options for purchasing a replacement, ranging anywhere from about $23 to over $30 each. One of the first and cheapest options came up on Amazon; here's a link to it.
Amazon.com: Makita 651922-3 Switch : Tools & Home Improvement
I assume you don't need disassembly instructions since you mentioned that you've already got the switch open, but you could take lots of photos as you work and use those to create the first guide here on iFixit to that repair. It's easy, fun and you'll earn the appreciation of the repair community. There are lots of us available to help if you need assistance creating a guide; all you have to do is ask.
Good luck and let us know how it all turns out!
Was dit antwoord nuttig?
Score 1
generally, the switch itself isn't repairable. Just replace it. If that isn't the question, then post more info and pictures.
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 416
