Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor kleine elektrische persoonlijke kachels.
Help Identifying Replacement Switch For Patton Space Heater
I was given a defective Patton space heater, model MH-761. It appears to have encountered an over-current episode as the two-position rocker switch used to switch between high/low settings is melted. I would much appreciate help in determining the exact type of Carling switch needed to replace the melted one.
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
All the necessary parameters are not obvious by your pictures or description.
What is obvious:
Snap in, SPDT, 16A @ 125V, quick connect 0.250 terminals
What is not obvious, and important:
Panel cutout dimensions
If the sw has a center off position
If it is lighted.
THIS page has all of what I perceive to be a snap in, SPDT, 16A, 125V, with quick connect 0.25 terminals. You can change the filters to see other switches. All of these require a rectangular - 28.58mm x 13.97mm cutout.
You might also search AliEpress to find a match.
NOTE: most of the switches with quick connect spade lugs that burn like that are caused by loose spade lugs. That heats up the sw terminal and melts the plastic. Make sure they are tight by squeezing the wire terminal with pliers, Gently. You don't want them impossible to put on.
Was dit antwoord nuttig?
2 opmerkingen:
Thanks for the info. I will need to research further. The cutout dim. are 19.20mm x 12.90mm, has no center off, and is lit. The only Carling sw I'm finding in that size all have a smaller amp rating. This one may work, although it's not lit.
https://www.ebay.com/itm/266624084537?_s...
door
Position 1 either 1250 or 1350 w position 2 is 1500 w the heater has a thermostat controlled single speed fan. The switch controls which coils are engaged. Position 1 some, Position 2 all. A SPDT on-on rated 3/4 HP 16A 125 VAC 60 Hz illuminated rocker The space heater should have a safety cut off if it tips forward. If activated one must right it, turn the rotary thermostat dial counter clockwise to off, and unplug the heater for a minimum of 30 minutes. When it has cooled, plug back in turn dial clockwise to maximum fan should run and coils heat. When desired ambient temp has been reached slowly dial back counterclockwise until fan stops. Leave in Position and heater will cycle on and off as necessary to maintain temperature.
Hope that functional information will help you figure out the wiring and identify the correct replacement.
door
Voeg je antwoord toe
n0rthernlights zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 647
