Ga door naar hoofdinhoud
Een draadloze, meer traditionele videogamecontroller geproduceerd door Nintendo voor het Switch-systeem. Modelnummer: HAC-013.
Botched Pro Controller Joystick Replacement - Is it salveable?
Hi everyone, I tried to replace the left joystick on my Nintendo Switch Pro Controller. Unfortunately, as the title says, I botched it. I managed to desolder most of the solder points for the joystick, but I still couldn't detach it.
In the process of trying to get any residual solder off the mounting pads, I partially ripped one of them. I think I need to get solder flux to try to get the remaining solder to flow to detach the joystick. However, I want to get the opinion of those more experienced to find out if I passed the point of no return before proceeding. Pictures are below.
Afbeelding
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
is it the bottom left in the photo
Was dit antwoord nuttig?
2 opmerkingen:
Yes it is. You can see the torn pad on the right side of the mounting points in the bottom left of the picture.
door
@smoothbrain looks similar to the pins above so i would say its a ground pin and fine to connect both together, so the bottom pin to the 1 just above with either a jumper wire or solder blob which ever is easier for you to do
door
Voeg je antwoord toe
smoothbrain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 339
