Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-, demontage- en probleemoplossingsinformatie voor de HMD Fusion, van de makers van de Nokia-telefoons. De Fusion werd in september 2024 gelanceerd en bevat een verscheidenheid aan slimme outfits die aanpassingen mogelijk maken.
Is there a FM radio module?
The presentation page of the phone on the Ifixit site is, to my knowledge, the only page mentioning the presence of this module. (some other websites mention that there is no such module and the brand site doesn't say anything about it).
So is it possible to listen to the radio without needing an internet connection?
Thank you for your response!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @paulgrougnie
FM radio on a mobile phone uses the wires of your headphones or earbuds as an antenna to pick up OTA radio signals.
You don't need an internet connection.
This of course depends on whether the phone has an FM radio chip on board or not. You also need to install an app to gain access to the chip to listen to the radio.
As you said there's conflicting information regarding whether your phone has this feature or not. Easiest way to verify is to download and install a free radio app, plug in a set of headphones and check if you get radio or not. It may be that the app won't install as it cannot detect the FM chip to connect to. Not 100% sure of this though.
Search the Play Store for radio apps (examples only) to find the one that you prefer.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I don't have one, I compare phones and need information about the features I need. I contacted the support of the brand that claims that the FM chip is present
door
So I finally bought one and the definitive answer is : yes there is an fm chip!
door
@charlie_02 Thank you for following back and letting the rest of us know!
door
Voeg je antwoord toe
Charlie_02 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 42
Altijd: 992
