Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De 13" MacBook Pro, uitgebracht in mei 2020, is uitgerust met quad-core Intel Core i5- en i7-processors van de 8e generatie en een geïntegreerde Intel Iris Plus 645-grafische kaart. (Model A2289/EMC3456 met twee Thunderbolt 3-poorten)
How do I replace the camera?
My camera is not working, can someone explain how to replace it please. The green light comes on but no image
Thank you
Is dit een goede vraag?
8 opmerkingen:
Not sure what happened. I posted an answer here and I was notified that you commented on my answer. However, my answer is nowhere to be found now.
door Deel
@wenchao - It was deleted as your answer is a very different setup with the older Unibody systems.
door Deel
@danj Sorry about that, but the basic troubleshooting princle shall apply: make sure it's the camera by testing another assembly before proceeding the difficult part of replacing it.
door Deel
@wenchao - Apple makes testing on the there M series very difficult at the physical level. At best you have the onboard diagnostics.
Replacing is not really done, here the full display assembly is swapped out as the lid assembly is not easily opened and replacing the camera is just not done.the camera is serialize to the system.
door Deel
@danj "the camera is serialize to the system" does it mean the replacement camera wouldn't work?
I knew that a few iPhone componenets were binded to the system such as touch ID, which many people complained about. What good does it do for Apple?
door Deel
3 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Start by resetting the NVRAM and SMC. If that doesn't help, then you know you have a hardware issue with the display. Replacing the camera itself on these models is not easily done. You would need to fully disassemble the display assembly and do some very delicate microsoldering. The more feasible approach is to replace the display assembly, but the displays on these can be pretty expensive. Here's a link to a display. Good luck!
Was dit antwoord nuttig?
Is this the original display that came with the system?
You might be better off just using an external web cam when necessary as the 'repair' to fix the possibly damaged camera is a nightmare of a job when it comes to removing the screen glass and all to get to the camera part...... Have you checked inside that all the cables are in place..... MacBook Pro 13" Twee Thunderbolt-poorten 2020 Vervanging van de schermmodule
Voeg je antwoord toe
Ronald León zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 687
