Ga door naar hoofdinhoud
De Anywhere Mouse MX is een lasermuis die in 2009 door Logitech werd uitgebracht. De muis maakt verbinding via een Logitech Unifying-ontvanger en wordt gevoed door twee AA-batterijen.
I have broken a pad SW1 (again)
Hello!
I have broken my second Anywhere MX 1 mouse when replacing the SW1. The pad broke again near R6 (signal one, the ground is fine) and I was certain to not break it again. But it happened.
Is there any chance that anyone has got the schema or idea where the signal comes from? I would love to make a jumper and get my favorite mouse to work.
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
is this copper, can't tell with the flux
Afbeelding
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I've edited my post and added photos of front and back. I've checked the C6, which appeared to be connected through a hole, but that side od capacitor appears to be a GND.
door
Nope - it is a PCB. The pad fell off. The only thing that is copper is the little hair trace that's left.
door
@makerbuddy have you got a multimeter
door
Yes I do, so I could tell that the trace goes to ground.
Besides I was working on it and today managed to catch the copper trace that was left from the pad. Used some copper wick as a new pad and everything works fine.
Besides that I still did not got idea where it goes! I've checked every component and signal points, but none of them was giving a beep in continuity test with multimeter...
door
Voeg je antwoord toe
MakerBuddy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 328
