Ga door naar hoofdinhoud
It is not charging
What I plug it in it doesn’t charge but it works perfectly fine
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@cskamga possibly a bad battery. First check your charging cable. Check to make sure that the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out.
If all of that is okay, replace the battery and then re-evaluate. Since iFixit does not yet have a guide for this, use something like this video
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Voeg je antwoord toe
cs kamga zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 533
