Ga door naar hoofdinhoud
The iRobot Braava Jet M6 was released on July 12, 2019. It is a robotic mop that can map out rooms and cleans floors by spraying water and mopping with a pad attachment.
Braava m6 not responding; not turning on and buttons don't do anything
I recently bought a used Braava Jet m6, and the robot does not respond. When I put the robot on the home base charging dock, for a few seconds, it lights up white and spins, and then it stops. When I press the "Clean" button, the robot doesn't respond. The same for all the other buttons. The wheels are not jammed and I already tried holding Clean for 30 seconds. It came with 2 batteries but they don't seem to work. The robot gets a little warm on the place where the cleaning pads are mounted. I have no idea what could be the problem, and I appreadiate any help I can get!!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
After a time my iRobot Braava m6 mop just stopped working all together.. I did the usual troubleshooting steps, namely: 1. Made sure everything was ready to go, clean and orderly 2. Removed the app (or widget) from phone then reloaded it. 3. Removed the battery waited 5 minutes and then reinstalled the battery. 4. Disconnected and reconnected to Wi-Fi. 5. I should mention that I didn't have any error messages. I called iRobot and they thought it was a dead battery so I bought a new battery ($90). Still no function. I ended up purchasing a new Braava m6.
Just a note: My m6 was probably 5 years old.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jonathan Trapp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 90
Altijd: 439
