Ga door naar hoofdinhoud
Informatie over reparatie, demontage en probleemoplossing voor de Xbox Series S, Microsofts nieuwste compacte, volledig digitale spelconsole. De Xbox Series S werd op 10 november 2020 uitgebracht naast zijn krachtigere grote broer, de Xbox Series X.
Stuck thinking it has wired connection
I have recently had issues with a thunderstorm that took out my internet connection and since my Xbox thinks it still has a wired internet connection but wouldn't connect to internet to play games. 8 tries resetting the settings and it won't go to wireless internet as it thinks there is a connection in the LAN port when there isn't. I then reset the console but now won't do the required update when setting up the console from factory settings. I even tried usb boot drive and no dice. Any help would be greatly appreciated.
Is dit een goede vraag?
2 opmerkingen
Have you been able to find a fix? This just happened to me. I ordered a new wifi card to see if that fixes it and it comes in today.
door
Mine is fixed. Turns out after a complete drop down including all software updates it turned out to be a ribbon between the 2 last boards to split.. deepest ribbon cable 🤬🤬
If your UK based and have the same issue these guys will tell you all about it ( Mansfield Tech Hub )
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi Gareth!
Did you tried an actual network cable and see what happens? I would try this first. Just go to your modem and connect it with a network cable just to check. When it does have network, then you can do the actual update(s). Then remove the network cable, maybe the error would be gone by then.
Please let us know how it goes!
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I have the same problem and multiple network cables and days and it still says the same
door
Please sent us some photo's regarding the error.
door
Voeg je antwoord toe
Gareth M Clifft zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 119
Altijd: 2,274
