Ga door naar hoofdinhoud
Ook wel bekend als de PS one, of de PSOne, dit apparaat is de slanke versie van de originele PlayStation, uitgebracht in 2000.
Weird graphical issue stripes
I have a stripe going down the middle of my screen was hoping someone may know a fix i could do to solve the issue.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
Yeah, I recognize this issue and it's not good.
Your GPU is probably dying and as it's hard (almost impossible) find the GPU chip, you probably do need to replace the motherboard to get this fixed.... Is it modded with a modchip? If yes, please remove this first to see if it's solved or not. Probably this won't solve it, so a motherboard replacement is required. Motherboards are also very hard to find.. So you can buy a donor-broken motherboard with other issues, so you can take the component of it. This is very hard and you do need solder experience.
Sorry for the bad news...
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
That is fine I've got a donor I just wanted to see what the possible issue could be ill give that a go thank you :3
door
My pleasure! If you need anything else, please let us know :)! Good luck with the repair!
door
Well the only other question i'd have is are the other gpu chips interchangeable or do i need that models chip to replace it?
door
You do need the exact model unfortunately..
door
Voeg je antwoord toe
Kurono zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 295
