Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Remove and install the AMD GPU chip
What sort of workstation would it take to remove and install the AMD Radeon HD 6750M GPU chip, and what do I want to look for on the used market to get one? Second question, are there better fans to put in a 17" Unibody MacBook Pro?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
I don’t think the pinouts of the NVIDIA GeForce 9600M GT chip is compatible with the AMD Radeon HD 6750M.
Even still the Radeon HD 6750M doesn’t have a good history. I burnt out three GPU’s and I was only working editing large photos with a late 2011 model. I jumped to 2015 15” MacBook Pro’s which has a much better Radeon R9 M370X GPU.
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
The AMD Radeon HD 6750M is what the MacBook Pro currently has, and what this series came with.
It hasn't failed yet. It is showing its heat sensitivity. If I can get more cooling for it, it might survive. If not, then I need to replace it.
door
@wnlewis - OK, the way you phased the Q implied you had the one of older 2009/10 models.
I would install a good thermal monitoring App like TG Pro so you can monitor things of course I would refresh the TIM paste as what Apple used back then wasn’t very good. Even still don’t over do it! It’s not a quantity thing it’s a coverage thing with a thin coating.
You might want to inspect the heat pipe for pin holes as sometimes the coolant leaks out. TG Pro can help push the fans to shed the heat more aggressively when it’s called for (you set the threshold) or you can turbo the fans as well when you think the action you are about to perform will need more cooling. I would do that, there is no other fan that’s any better than what the system came with.
As far as replacing the GPU chip, you won’t find any new ones, at best you might find a junker which still has a working chip. Replacing the chip requires some special gear what is called a rework station.
door
The rework station preheats the logic board and then focuses additional heat onto the chip so it can be removed. As you don’t want to shock the chip in question or the boards other components there is a procedure to ramp up the heat and likewise when you allow the board to cool.
door
@Dan Thank you. That is what I needed to have answered: Look for a parts only machine at a bargain price; use a rework station to trade out the chip; look for and work on any pin holes. Is there a way to add coolant and reseal the heat pipe? And what type of coolant was used?
door
@wnlewis - Remember a used systems GPU lifespan maybe short as well as this GPU had a lot of issues! Issues with the AMD Radeon HD 6750M GPU it wasn’t an Apple only thing and both 15” & 17” where effected. So do keep that in mind before over spending and many newer graphical Apps which need Metal support won’t run.
Sadly you can’t patch the heat pipe or refill it. Your only option is replacing it.
I cried for a good week when my last 17” finally died its’ last death! As I too didn’t want to part with it either. Finding a good chip is extremely hard and there are a lot of sellers who will try to sucker you into buying a dead chip and then not refund you claiming you killed the chip or where trying to pass yours as theirs.
door
3 commentaren meer tonen
@wnlewis the issue here is not the cooling of the chip but the design of it. The processor is a flip chip design and the issue for the failure is commonly caused by the solder bumps between the IC and the substrate. The proper definition of that can be found at Wikipedia "is a method for interconnecting semiconductor devices, such as IC chips and microelectromechanical systems (MEMS), to external circuitry with solder bumps that have been deposited onto the chip pads." It does not matter if it is a MBP a PS3 or a XBox, due to the constant heating and cooling of the IC, the bumps that connect the chip to the substrate lose contact and your chip (in this case processor) fails.
Afbeelding
As you can see the "bumps" are what actually connects the die to the substrate to make the chip complete. If these bumps fail, the die does no longer make contact with the substrate and thus no contact with the circuit board. The chip has failed.
Afbeelding
Here you can see the space where the bump has failed and no longer makes contact. We are talking microns of space here.
Sometimes a bit of pressure on the top of the die potentially close the gap. Same with a reflow, which may allow some of material from the bump to reshape and starting to make contact again. The heating of cooling of the chip during use is what will eventually cause it to fail again.
If you are going to do a reflow then the general guidelines for a good profile would be something like this:
Temperature ramp up 1ºC/second
Peak temperature should be 200C to 210C
Remain above liquidus (183C) for 45-75 seconds
Do not heat any packages above 220C since this will most likely destroy the IC. Sure, you could just blast the chip with some hot air and it may or may not work, but it'll be a bit of a crap shoot. Through the whole Xbox and PS3 debacle of those failed chips, I invested in a IR reflow station. It was something like $250 USD on ebay and used that for a few successful repairs.
Here is a good document that will help you with the profile as well BGA-Reflow-Rework.pdf.
Now, to replace the chip completely, you are looking at a reball. Which is far more involved and will require some practice and definitely the right rework station. For that you need the right stencil, the right balls as well as a reballing station (those are not to expensive).
Everything on here can be learned by practice but the main challenge will be to find a replacement. You will most likely only find used ones (maybe from a functioning board) but because of the actual design, you just will not know how long it is going to last. You'll be spending a lot of money on something that may only be temporary. So, blasting it with a hot air gun may just be a more economical attempt to revive this. At least get a thermometer and some thermocouples so that you get within the ballpark of the right temperature.
As for the liquid inside the heatpipe, we don't know what Apple uses but for computer cooling applications the common combination has been copper as a fluid container and water as a working fluid. Other working fluids can be ethanol, acetone, and even ammonia. Flammability is an issue and that is why fluids like ethanol etc. are not commonly used. Since these heat tubes are either filled under vacuum, the DIY'er can't really repair those.
As you can see, it will all depend on how far you want to go with all of this and how much money you are willing to invest. Anything is possible, just a matter of how many resources you want to mobilize.
This is just a quick and dirty explanation of what has commonly affected the flip chip designed GPU.
Repair is War on Entropy!
Score 1
1 Opmerking:
I am very familiar with what you have described having worked as a contract Industrial Engineer for an electronic's board manufacturer for the aircraft industry. I did time and material studies to make sure that they were making a profit on several of the products in their line. So I am familiar with PCB software, Gerber files, fiducials, Juki Pick and Place machines, tombstoning, solder stencils, BGA stencils, solder ovens with chain conveyors, etc.
Since the image on the computer is good, and since it only occasionally fails to display (black screen), I think that your assessment of breaking solder bonds is probably correct.
Thank you for the information about typical cooling fluids and typical metal used for the tubes.
I will have to think about the costs to get into the business myself and whether or not I can find the necessary equipment and software at bargain prices. If not, then a hot air gun and thorough cleaning inside the computer to aid cooling may be the answer.
door
Voeg je antwoord toe
Wm Neal Lewis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 39
Altijd: 605
