Ga door naar hoofdinhoud
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
20 Vragen Bekijk alle
Can I replace the screen and battery at the same time?
I've got an iPhone SE 2020 that needs a battery replacement. The screen isn't in a great condition, but will probably last a bit longer. Since both battery replacement and screen replacement look like bigger jobs, I'm wondering if I can do them at the same time?
It looks like the repair guide for the battery replacement suggests removing the screen - can I just swap the new one in at that step, or is there some extra steps? It looks like I'll need to do something with the home button too.
Has anyone done this, and is there a recommended order of steps combining the two guides?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Yes you certainly can.
just follow the battery replacement guide.
iPhone SE 2020 Vervanging van de batterij
Stop at putting the display back on.
When it comes to putting the display back on you can follow the guide for replacing home button guide.
iPhone SE 2020 Vervanging van de thuisknop/Touch ID-sensor
Scroll down to where the display is removed and follow the steps to replace home button.
This is where you will remove the home button from your old screen and fit it to the new screen.
Be sure to click in any “blue” comments to see if there’s further advice regarding each step, so you don’t tear the flex and lose Touch ID or home button function.
Hope this helps
iPhone SE 2020 Batterij Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
iPhone SE 2020 Thuisknop/Touch ID-sensor Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
1 Opmerking:
This is super-clear! Thank you! I'll try it as soon as the parts arrive!
door
Voeg je antwoord toe
PCZA zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 59
