Ga door naar hoofdinhoud
Handleidingen met reparatie en ondersteuning voor een brede waaier aan kunst.
I’m from the uk what is “cardstock”?
I have no clue what you are saying when you say “cardstock” card? Cardboard? Some example of what card is the correct weight and thickness would be extremely helpful… or better still a link to an ideal piece of card that I can acquire in the UK please
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Its a thicker piece of paper that is stronger than normal paper but not quite cardboard, its the same stuff that buisness cards, playing cards, etc. are made out of hence "cardstock"
Construction paper is very similar in use and usability, you can probably get it at your local arts and crafts store, if not here is a 300 piece 8.5 by 11 inch box on amazon
Was dit antwoord nuttig?
Score 2
Hi @nics93686
Cardstock is another term that refers to a grade of paper, usually determined by its weight
Here's a guide showing the different paper weights and their uses.
Search online for cardstock UK suppliers to find one that suits you best. (examples only.
Score 1
Voeg je antwoord toe
Nics zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 39
