Ga door naar hoofdinhoud
The Motorola Razr V3c is a CDMA2000 version of the Razr.
8 Vragen Bekijk alle
How do I retrieve photos from a severely damaged Razr V3
I ran over my Motorola Razr V3 cell phone with my car! Its literally in pieces! Options in regards to retrieving photos? Within which actual component are the photos stored?
Is dit een goede vraag?
Score 1
1 Opmerking
This question was migrated from http://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Mike, unless you stored your files to a memory card (which only some version of the V3##) had access to, or transferred it previously to your computer, the information will be saved onto a memory chip on your logic board. In the case of the V3 it is a PF38F4050L0YBQ0 flash memory chip. It is only possible to retrieve it if you
1. have a flash memory IC reader or
2. have the knowledge to build one and
3. have the right software to read the information.
That is why professional services charge hundreds of Dollars to retrieve that information. Maybe you have a connection with some digital forensics expert that could assist you with that. If your logic board is viable, you might think about fixing your phone.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Digital forensics 9.9 *drools* I wanna learn that stuff so bad haha. I wanna be that guy in a heist "GIMME A MINUTE I'm hacking in the mainframe!!"
door
Yeah,if the SD card is okay ,then you can retrive your lost photos easily,or we can say that part the memory card.
You can use some "Card reader" to see whether your pictures are still here,if not,you should use some special photo recovery software to find baxck you lost photos.
Hope this will help you.
Similar problem here. Phone has the “Snow Crash” but want to see if anything is salvageable.
Incidentally some devices especially Moto tablets NEED the SIM card in to complete setup, guess this got missed out of the manual. Worth a try if it seems stuck.
Voeg je antwoord toe
Mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 5,927
