Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een draadloze, meer traditionele videogamecontroller geproduceerd door Nintendo voor het Switch-systeem. Modelnummer: HAC-013.
Pro Controller Left Joystick Input Dropout
My left joystick's input seems to dropout momentarily, especially when I push it in any direction in the top half of the joystick (i.e. directly up, up-left, up-right, etc.). I already tried taking the controller apart and putting cleaning solution in the joystick (i.e. BW-100), but it only solves the problem temporarily. Is there anything else I can do that doesn't involve replacing the joystick?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
i’m afraid that you do need to replace it… when you test the joystick in the settings menu of the Switch, what are the results? Maybe you can just calibrate it. Is the controller also up to date?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I did recalibrate, but the issue didn't completely go away. When I move the joystick around the upper edge of the left joystick, there's the dropout is less pronounced but still there. Controller is up to date.
EDIT: Slight edit for clarity.
door Deel
Alright, then I’m afraid that you do need to replace it :(… you do need to solder and have some solder experience. I replaced some of them and the good thing is, is that the solder melt really easily and that replacing it is easier then like the PS4 controller joysticks.
door Deel
Voeg je antwoord toe
smoothbrain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 270
