Ga door naar hoofdinhoud
Ondersteuning voor de Texas Instruments TI-84 Plus rekenmachine.
Calculator seems to be unresponsive
My calculator turns on and shows the ram cleared after turning on and then when you try to input anything the cursor just gets stuck and hangs. Nothing happens after that. it is unresponsive and does not responds to any input given and just stays blank. i have removed all the five batteries and replaced but still the same. when i try to connect it with my laptop it not being detected by the software.
Afbeelding
Is dit een goede vraag?
2 opmerkingen:
are you saying some of the keys work and it locks up after hitting those keys?
door
no after hitting the on button it locks.
door
Voeg een opmerking toe
1 Antwoord
Check the I/O port for any debris. Sometimes dirt will confuse and freeze the calculator.
You can try an OS reinstall. Take out one battery then hold [Stat] while putting the battery back in. It should say something like 'send OS new' or 'waiting for OS'.
Now plug the calculator into your computer using the USB cable and send the OS. You can download it from TI's website or directly from TI-Planet: http://ti-pla.net/a2111
It will take a few minutes to install.
Was dit antwoord nuttig?
Voeg je antwoord toe
Yunus Panthodi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 396
