Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Touchscreen works badly after installing new front panel
(Iphone 3GS 16 GB)
Hey,
i removed my broken touchscreen few days ago and installed a new one, using the instructions on ifixit.com. At first sight it looked like everything was working but then i found out the bottom part of the touchscreen doesn't react. The upper sector does react, but not even nearly as good as my original one before ( even in broken condition).
I wonder what's the reason...
Guess it may be hard to analyze the problem without seeing the phone but If i'd demaged something just as the ribon cable 2 would the touchscreen work partly just as it does ?
I used a quiet cheap front panel so could this be the only reason for the faulty ?
Would be so great if you'd tell me your expections, because i just don't know if it would make sense to buy a high quality panel and install it.
Thanks!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The only times I have had this issue either:
- The connector wasn't fully engaged and just needed popping off and re-seating
- Small tear in the cable for the connector
- Bad part
there is a slim chance that the connector on the logic board itself was damaged in the original incident but I think I've only seen 1 phone with this issue and I put it down to a DIY fix gone wrong.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Lena, sounds like a bad digitizer. Contact your vendor and see if they are going to replace the one you have.
door
Definitely sounds like a bad digitizer to me. Or just the ribbon connector, worth checking if it's popped on properly.
Score 1
Voeg je antwoord toe
Lena zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 487
