CD drawer stuck closed.
Where is the auto release hole located?
Is dit een goede vraag?
There is no release (or eject) hole in the CD unit.
Use a thin flat tool e.g. flat metal spudger or even a suitably thin knife etc and slide it gently under the CD tray, on the left side until you feel the catch release.
Was dit antwoord nuttig?
It didn't work. I felt something catch but which way should I move it? I tried up/down/right/left
didn't open.
Under the disc port there should be gears on the left side use a flashlight and look into the hole and grab something thin hard and long enough to fit in the hole I used a knife but all you do is push the gears and they should start turning and when the disc slider pulls out enough for you to be able to grab it pull it out the rest of the way
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 62
Altijd: 847
