Ga door naar hoofdinhoud
De Skullcandy Hesh 2 is een set draadloze Bluetooth-over-ear hoofdtelefoons verkocht door Skullcandy. Het model Skullcandy Hesh 2 is te identificeren aan het modelnummer S6HBGY-3xx.
Sound too low on bluetooth mode.
The sound on bluetooth mode is too low but when i connect it with a wire it give normal sound. Tried different devices but insisted on the same problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@syedalam81869 since everything works as it should, except the volume, I suggest you try a new battery. This of course is never easy since they (manufacturers) do not want us to fix things. With these headphones it’s fairly straight forward. Basically, you remove the earpads. After that, remove the four screws that hold the driver to the housing. The battery is behind the speaker nestled into the headset. I suggest you check this video (it’s dreadful but has a bit of valuable information on how to remove the drivers (speakers). Use this document Internal Photos 2316351 for the rest of it. The second picture shows you the battery etc.
Was dit antwoord nuttig?
Voeg je antwoord toe
syed alam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 177
