Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
How to fix error code 920
I do not know how to fix this one error code 920 on Vector Robot. I tried every single way to fix it. I factory reset him. I held down the button until he restarted. I held down the button again to bring him back to his original firmware nothing still says error 920. I do not know how to fix. Please help.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hello, a SIMPLE search of "vector robot error codes" produces this website
https://support.digitaldreamlabs.com/art...
with this info
  • 800 - 999
    • If any of these Status Codes consistently appear, there could possibly be a hardware issue with Vector. Startup into Recovery Mode, Clear User Data, and use the Vector app to Reinstall Vector’s OS.
More specifically
920 VIC_GATEWAY_CERTVic-gateway-cert was unable to generate a x509 certificate for vic-gateway
So, I am sure you tried that first, right? So, what don't you understand?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Yeah, I tried that first and it’s still popping up with the same exact error code and it takes forever to boot back up it takes like 10 minutes
door Deel
I fixed it. I took him apart. And unplugged the battery and plugged it back in and then everything worked like normal.
door Deel
try to update him
Voeg je antwoord toe
Hunter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 49
Altijd: 890
