Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Operating system not working
I need to change my operating system from the outside of my computer
Is dit een goede vraag?
Score 3
3 opmerkingen
Could you please give more details?
What operating system do you have now and which one do you want to change it to?
By "outside" I think you mean using an image on a USB flash drive. Is that correct?
door Deel
What do you mean by "not working"? What is the specific issue here? By changing your operating system from the outside, do you mean reinstalling it via a flash drive?
door Deel
جربت ولم ينفع
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
Given the context of the question, I would recommend finding a tech savvy person to help you.
Was dit antwoord nuttig?
Score 1
Well I will suggest you to checkout the following video: https://support.lenovo.com/us/en/videos/...
You can change or reinstall your OS using a bootable USB. Just create a Windows installation USB using another working PC, plug it into your computer, and boot from it to install Windows. Make sure to back up your important files first so you don't lose anything.
You can reinstall your operating system using a bootable USB drive, even if your computer isn't starting normally. Create the USB installer on another working computer, boot from it, and follow the installation steps. Make sure to back up your important files first, as reinstalling may erase your data.
Voeg je antwoord toe
david-praise felix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 57
Altijd: 571
