Ga door naar hoofdinhoud
De draadloze Xbox One-controller werd geïntroduceerd in 2016 bij de lancering van de Xbox One S en voegt Bluetooth-ondersteuning toe voor Windows 10/11. Deze controller lost veel van de ontwerpfouten op die in de Model 1537/1697-controllers werden gevonden en is veel betrouwbaarder. Deze controller is vervangen door de verbeterde Model 1914-controller.
Left Stick Constant Input Down
I attempted some maintenance on my controller a couple of weeks ago, using some 99% IPA to scrub the potentiometers of the joysticks to my controller, as well as the joysticks themselves, and other areas of the motherboard. However, as a result, the left stick has been constantly giving input downward according to the direction of the stick.
I have attempted to clean the potentiometers again, as well as replace the left stick just today, to no avail on resolving this new issue.
Upon testing for continuity, I noticed that the pins in the potentiometer intended to input vertical LS movement do not seem to have a connection. This is after clarifying that all of the opposite pins on all three of the other potentiometers in the controller returned a status of continuity existing between them respectively.
I am wondering, then, what the problem could be with the controller. Thank you for reading into my inquiry.
Afbeelding
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Aiden!
How are the solder pads? Still good? If those are damaged it can cause the issue you are having.
Also, check the other components near the sticks on the motherboard, maybe something is damaged there.
Please let us know how it goes!
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi there, what could I do in the event that the solder pads are damaged? How could I bring the controller back to operation in such a case?
door
Depends on how it is damaged! Can you remove all the solder and sent us a new photo? Thanks in advance!
door
Voeg je antwoord toe
Aiden zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 254
