Ga door naar hoofdinhoud
Model M5343 / 333 or 400 MHz G3 processor
11 Vragen Bekijk alle
Schematics for the PowerBook g3 lombard?
My powerbook g3 lombard won't turn on and I don't know why. The fan does not spin and the cpu doesn't get hot when I try to turn on the computer. I also tried replacing the 10v 100uf tantalum capacitors but it didn't make a difference. Not even the service manual helps.
Is dit een goede vraag?
5 opmerkingen:
@maxplayz what numbers are printed on the logic board?
door
Do you mean the logic board part number?
door
@maxplayz anything like 661-2174 etc or a 820-____ number You did check to make sure that your power supply is still working etc.? You have checked the power/charging board for any damage? Which capacitor did you change and why? Post some good pictures of your boards with your Question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
door
@oldturkey03 it's a fully working power supply and the capacitor I replaced was the 220uf 35v capacitor
door
@maxplayz how did you check that the power board is working? What voltages do you get on the board?
Post some pictures of your boards with your Question That way we can see what you see.
door
Voeg een opmerking toe
1 Antwoord
Post your request on BadCaps web site see if someone there can help you.
Was dit antwoord nuttig?
Voeg je antwoord toe
Max Playz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 44
