Ga door naar hoofdinhoud
De Lenovo IdeaPad 3 15IIL05 is een mid-range laptop die is ontworpen voor algemene computertaken.
The laptop screen is blank
Laptop charges and can power on.
Using an alternate monitor works. Using remote control apps like parsec works. Camera works. Am able to take and save screenshots using memorized keystrokes while powered on. Laptop has been reset multiple times, little or no user files or configuration exists outside of windows 11 account creation
When using an external monitor, the laptop only recognizes the external monitor and does not detect multiple monitors.
There is no visible, external damage to neither the case, nor the screen. (Though when opening the case, a few plastic latches have snapped off)
Limited knowledge points me to a bad backlight possibly? The screen isn't dim or dark, but appears to not be powered on. I would hope it's some driver issue, but I can't seem to get a lead on that.
If I could get some confirmation, that'd help with the confidence to move forward to try and fix this.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @mersen83836
With the laptop turned on, try shining a flashlight at an angle close to the laptop screen and check if you can detect any images on the screen at all.
They will be very faint if they are there so trying this in a darkened room may help to see them.
If you can't see any images then there's a problem with either the eDP cable, eDP cable connection (at either end, motherboard or LCD panel), or the LCD panel itself.
Here's the hardware maintenance manual for the laptop. Go to p.51 to view the procedure to remove the LCD panel. This will allow to to inspect the cable and cable connections at least.
If it is determined that the LCD panel is the problem, here's the parts list for the laptop.
Click on Select Commodity → LCD Panel (17) to find the part numbers for all the LCD panels that can be used in the model. Usually the part number can be found onthe back of the LCD panel itself, if you wish to verify which one you have now. Search online for the part number only, appropriate to your particular laptop, to find suppliers that suit you best.
If you can see images then there's a backlight problem with the display. Here's the motherboard schematic that may help. The power for the backlights is fed via fuse FG3301 (fuse type 3A 32V ERBRD3R00X (example only) to pins 1 & 2 of the eDP cable connector - see p.33 of the schematic.
If there is power on pins 1 & 2 at the LCD panel end of the eDP cable then the problem is in the LCD panel, which will have to be replaced.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
mersen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 601
