Ga door naar hoofdinhoud
De DJI Mini 2 is een kleine drone die in 2020 door DJI werd gemaakt. De DJI Mini 2 beschikt over 4K/30fps video en een videotransmissie van 10 km met 720p/30fps.
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
Is dit een goede vraag?
Score 1
1 Opmerking
did you solve this problem?
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
door
AC is a common abbreviation for AirCraft
door
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
door
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
Score 1
2 opmerkingen:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
door
did it beep at startup?
door
Hi, Have you done any repairs recently? have you crashed recently?
4 opmerkingen:
very minor fall from about 8' into grass
door
Yeah, it looks like you messed up your gimbal
door
posting new answer...
door
finally was able to find solution, i replaced gps board and all is once again fine!
door
Voeg je antwoord toe
colderp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 64
Altijd: 2,789
