Ga door naar hoofdinhoud
Reparatie-informatie voor diverse gereedschappen.
Tools for smartwatch repair
Hi i am looking for relevant tools to repair smartwatch with respect to hardware and software.
I am using amazfit gts 2 mini
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @shubh8030
ifixit has a range of pry and opening tools that should be able to open the watch.
Here's a video that may help you to open the watch
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
Thanks for sharing the video it will really help, I am also looking for software tools to fix its software
door
@shubh8030
You may be out of luck as far as software is concerned as the manufacturer's only provides a user manual and EU conformity certificate on their support page for the watch and no software downloads.
You could always try contacting Amazfit on support@amazfit.com and ask them. It never hurts to ask ;-)
door
Yeah I did it but they are asking for money to fix 😄
door
@shubh8030
You never know, replacing the battery might fix the software.
When you have disconnected the battery either do not reconnect the replacement battery for a few hours and then connect and assemble etc and fully charge the battery before turning the watch on or if the Power On button is still connected to the motherboard, with the battery not connected, press and hold the button operated for 30 seconds.
This will drain any residual power from the board and hopefully might correct any software glitches.
Won't hurt to try as the watch is disassembled anyway.
door
That’s good way to give a try thanks a lot will update you soon 👍
door
  1. An ability to open the device (iOpener)
  2. A razor (not one that you use to shave) (Buy one here)
  3. A spudger (any one works but here is ifixit's)
  4. Tweezers (pointed screwdrivers are important)
  5. Picks (a guitar pick works too)
  6. A screwdriver with a set of screw heads (ifixit's)
These tools are for apple watch repair, your's might be different but hopefully this is all you need
Tools for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Afbeelding
Product
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive. Afbeelding
Product
iFixit Opening Picks (Set of 6)
$4.95
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Afbeelding
Product
iOpener
$24.95
A large curved razor blade Afbeelding
Product
Curved Razor Blade
$9.99
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices. Afbeelding
Product
iFixit Opening Tool
$5.95
With a polymer driver handle and 32 bits, iFixit's Moray Driver Kit offers maximum utility in a compact package. Keep on hand in a kitchen drawer, a car glovebox, or a toolbox. Afbeelding
Product
Moray Driver Kit
$19.95
Score 1
1 Opmerking:
Thanks for sharing 😄
door
Voeg je antwoord toe
Shubh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 1,184
