How to change the headphone socket on this computer?
And is there a special series-no. for the new socket I need to be aware of when trying to find the replacement socket online or in a store.
Is dit een goede vraag?
Your in luck! While a pain to replace as you need to remove the logic board to get to the inner case area where it’s glued with hot glue iMac Intel 21.5" 4K Retina-scherm (2017) Vervanging van het moederbord (you’ll need a heat gun to soften the adhesive to get it off). Here’s the needed part 21.5” iMac Headphone Socket and Cable. I find you really need to fully clean off the old adhesive and after warming the case area and the part a fresh application of hot glue is the best way as it’s hard to mount the plate tightly to the case with the old glue present.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 17
You can follow this guide to take it apart to have a look at the damage inside then follow the guide to add images to an existing question.
iMac Intel 21.5" Retina 4K Display 2017 Teardown
Voeg afbeeldingen toe aan een bestaande vraag
door Markus Norstrøm
Thanks Makus, the tearappart is only interested in the software. I need help to change the hardware part for headphones/mini jacks, sound out socket.
door Tanja
