Ga door naar hoofdinhoud
Help! My mac 'Pops' off at switch on!
My white un-web cam iMac takes four attempts to start up, making a 'pop' noise when failing, but then works well although can 'pop off' when woken from a long sleep.
Is it a bad power unit?
Please help!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes, My first guess would be the power supply. Lay it down flat on its screen.. remove the back.. usually if a power supply is "popping" it will have a distinct smell.. also looks for any buldging or swollen capacitors.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
I'm pretty sure it's the power supply because the original power supply that comes with this model is notorious for failure after long use.
door
Could be, but could also be a bad hard drive, use disk utility to verify your hard disk if that's failing, a failing drive can make popping noises.
Voeg je antwoord toe
Big Dan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 2,165
