Ga door naar hoofdinhoud
High pitch noise when standby or off
So I've had to unplug this monitor after each use since i sleep in the same room. But It doesn't make any noise when it's on.
It's inconvenient to unplug and plug every time. Is there anything i can do?
The noise is very loud close up and definitely noticeable from anywhere in my room(it's a big room).
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@parsivan sounds like your monitor has issues with either capacitor or coil whine. Time to remove the back cover and to listen to where the whine comes from. Sometimes some strategically placed hot glue or replacing the component will work. Let us know what you find out when you try to isolate the whining part. Post some pictures of it with your Question so we can provide you with some further ideas.Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
Parsa Mahmoodi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 31
Altijd: 342
