Ga door naar hoofdinhoud
De Asus ZenBook Pro Duo UX581GV, uitgebracht in 2019, is een unieke laptop met een primair 15-inch OLED-touchscreen en een tweede touchscreen net boven het toetsenbord.
Do I need to replace my screen?
My laptop developed this bright area across the entire screen.
Afbeelding
Not sure if I need to replace the video card or the screen?
Is dit een goede vraag?
Score 2
2 opmerkingen
Have the same issue since Friday - did you manage to resolve it?
Note it is only on the main screen, I have 3 other UHD screens attached with no issue.
Thanks,
W.
door
Hello. I also have the same issue. I don't know if I should buy a replacement screen from Amazon and install it. I'm afraid the quality won't be the same as the original, what do you think ?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@tanyarey it does not look like a video issue but more like a display issue. One thing to try is to attach an external monitor. If that displays the same line, it's your GPU circuitry (video circuit is built into the motherboard, it does not have a separate video card). If the external monitor does not show that line, it is your display that needs to be replaced.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Is this common because I have the same issue. I turned it on one day and it was just there.
door
@tmeverything heat and "high miles" are the most common causes for this. It is really not the screen itself but the components and solder on the driver boards. LCD screens are actually quite complex and sensitive.
door
Can GPU circuitry be fixed or is the laptop busted @oldturkey03 ?
door
@shanicecoleman it'll depend on the motherboard and which component has failed. Sometimes it's just a small SMD component that needs to be replaced and other times it is the GPU itself which might be difficult to replace.
door
Voeg je antwoord toe
Tanya Rey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 22
Altijd: 847
