Ga door naar hoofdinhoud
Repair guides and documentation for the Google Pixel 5 smartphone. Released October 15th, 2020. Model Number: GD1YQ, GTT9Q
Move a screen from one device to another
My Google Pixel 5's screen is cracked. I have an old Pixel 5 device, the screen of which is still intact.
I wanted to have the screen moved from one device to the other in a cell phone repair shop, but the man at the store fears that the intact screen might break if he tries to remove it from the device.
Are his fears justified? What can he do to limit the risk of cracking?
Using the device with the screen intact is not a solution for me: I have apps on my Pixel 5 that still work fine, but when I want to install those apps on the other device, the device refuses to do so because the app would no longer work under Android 14. :-/
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@chrisbastiaens there is really not a whole lot that you can do ahead of time. If you follow the proper way of doing it, it should work but can still crack.
Translation
@chrisbastiaens er is echt niet veel dat je van tevoren kunt doen. Als je de juiste manier volgt, zou het moeten werken, maar het kan nog steeds barsten.
Google Pixel 5 Vervanging van het scherm
Was dit antwoord nuttig?
Voeg je antwoord toe
Chris Bastiaens zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 23
