Ga door naar hoofdinhoud
Beschikbaar sinds 24 mei 2021. Een slanke, ergonomische Bluetooth-hoofdtelefoon met krachtig geluid.
The power Button is broken.
Yes I did.
I've serched on the internet for New Button but in vain.
Update (02/16/24)
If some one knows where can I buy a New power button. Please tell meπŸ™‚πŸ˜‰
Update (02/16/24)
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 1
3 opmerkingen
@abdulkaderassad do you have it open and you have checked the power button? Do you have some good pictures of this so what we can see what you see?
door
@abdulkaderassad we need to verify that your headphones are the JBL TUNE 710BT If not, let us know the exact model.
door
Yes it is tune JBL 710BT
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Let us see the actual switch that's underneath the button. Unscrew that circuit board and carefully lift it out -- give us a photo or two. I'd be that it's an inexpensive momentary switch that you can replace with some simple soldering; depending on how the switch behaves, though, you might even get away with electrical contact cleaner and rapid presses.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
@abdulkaderassad totally agree with the above answer. I am certain that this can be fixed by soldering a new switch in place. Hardest part will be to find one that matches yours, but it can be done.
door
Voeg je antwoord toe
abdulkader assad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 1,144
