Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
no sim card error
friend may have dropped phone top of phone plastic cracked around sim card holder and part of top of sim card holder at the eject hole. I tunes and phone try's to activate the phone but no sim car error in i tunes and phone just ask's to try again. I don't have service i just want to reload the phone with software so I can use wifi
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sim card is not pushing on the sim detect switch at the back of the sim card tray.
Temp solution remove sim tray edge and insert sim tray.
Was dit antwoord nuttig?
I had the same problem and tried several times with different sim cards. Still didn't manage to get it started. Is there anything else to do?
1 Opmerking:
Did you check to make sure that the sim card readers pins are still making contacts and did you clean them? Did you check the sim card detect switch at the back of the sim card slot? you might also want to check on here http://www.youtube.com/watch?v=tdE6zGTsF...
door
Voeg je antwoord toe
jeffreyclark1981 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 6,855
