Ga door naar hoofdinhoud
Repair and disassembly guides for projectors.
144 Vragen Bekijk alle
Repair/service guide for a Panasonic PT-L500U projector?
My Panasonic PT-L500U projector won't turn on unless you hold he cord in a specific position. I have replaced the power cord and the problem persists, I'm assuming there is something wrong with the "AC in" socket. It could be a wobbly pin or maybe something just inside, but it's definitely affected by the position of the power cord.
I'm no engineer, but I'm decent with electronics and have a feeling I may be able to repair the AC input if I can get my hands on an official Panasonic service guide or something like that. Any tips would be greatly appreciated.
Is dit een goede vraag?
Score 1
1 Opmerking
You can download it from from here. but I can only share for a limited time;)
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
David Kreitter, looks like you will need the Panasonic part K2AH3B000020 (number 2 on the diagram) which is mounted on the K-P.C board. cost for that is around $3.00. Not a terrible complicated job and I am certain you will get it done pretty quick.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you, good sir!
door
This is Addie from BrightWay in China, professionally supplying
projector lamps.
Have you ever considered to import from China directly?
The price will be more competitive.
If you are not the right person, do you mind pass my email to this right one? my email: addie@projectorlampchina.com
Thank you so much and await your comments!
Voeg je antwoord toe
David Kreitter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,085
